Old 22-May-2015, 1:55 PM   #2
Jake V
What direction is your DB8e aimed at right now?
Are both panels facing the same direction? If not, what direction is each panel facing?
I'd try aiming both panels at Buffalo (146 degrees on a compass) and see if you can get the Buffalo channels while keeping your Toronto channels. If you get the Buffalo channels but not the Toronto channels move your antenna one degree at a time from Buffalo towards Toronto to see if you can find a sweet spot. If that does not work, you can try aiming one panel at Buffalo and the other at Toronto (102 degrees on a compass). Set the panels so that they are 'outside corners'.
NBC (RF 33, 2.1) is at -12.5 dBm and will likely be impossible to get regularly.
