Old 22-May-2015, 3:47 AM   #1
Kasm
Unexpected Results
Hello, I recently bought an Antennas Direct ClearStream 4v from BestBuy and installed it in my attic. There is about 80 feet of new Quad shielded RG6 between the antenna and my TV. The is also a two-way splitter in the middle of that 80 foot run, that is currently not connected to anything. My results so far seem a big confusing to me. I have the antenna pointed towards the Providence stations (322 degrees). The channels I get are 51, 22, 49, 12, 13, and 17. This seems odd to me because I can't get channels 21 and 10 even though they are closer to Providence and/or higher strength than channels 22 and 17. Also channels 22 and 17 are almost 180 apart from each other. I tried removing the two-splitter and used a coupling, but that had no effect.
I really don't care about channel 10, but I would like to get channel 21 and if possible the Boston channels located at 348 degrees. Would replacing the 4v with the db8e or something else help?
http://www.tvfool.com/?option=com_wr...f1f0403fa9f006
Thank you!
Kasm is offline   Reply With Quote
