Thread: DIY Db8
Old 19-May-2015, 2:16 PM   #38
Originally Posted by kojo View Post
I have a db8 from Antennas Direct.it can yesterday in the mail. I haven't done much with it. But I guess it's different then yours and it will only get UHF signal and not vhf. I might have to start from scratch and build one like yours.
The new bowtie antennas don't pick up VHF as well as the older bowtie antennas because the baluns (4:1 matching transformers) now being used by the manufacturers are printed circuit board baluns. The older bowtie antennas used ferrite core baluns that were good for UHF and VHF signals.
DB4e and DB8e use PCB (Printed Circuit Board) Baluns, which are VERY lossy in Hi-VHF Band
http://www.digitalhome.ca/forum/show...10&postcount=3
To use this antenna for VHF, I recommend replacing the feed harness with two baluns and a splitter (in reverse as a combiner).
http://www.hdtvprimer.com/antennas/temporarypage.html
scroll down about 1/3 of the page to just before The 4228HD balun images.
When you use two baluns, one for each 4-bay, you must reverse the wire leads on one of the baluns as a test, to see which way is better. This is so that the two 4-bays are fed in phase so that the signals from each are added together.
