Old 16-May-2015, 8:16 PM   #7
Tim
Originally Posted by killjoy View Post
Per the specs published on the Y5713, it looks like the 1/2 power range is 55*. My 2 channels are 68* apart. Should I be looking for a less directional VHF Hi antenna that can cover the spread? Or do you think with WJBK being so close (4 miles, -20dBm), I'll pick it up w/o even trying? How would you aim to best cover these 2 station with that one yagi?
Do you already have a Y5713? Since the demise of AntennaCraft they are becoming rather difficult to find. Maybe someone here can suggest an alternative.
My guess is that since you are line of sight and only 4 miles from channel 7 and they are running about 27 kW, you should have a very good chance of receiving it while your antenna is pointed at channel 9. I would start with the antenna aimed at channel 9 and see what kind of signals you get and then rotate in small increments towards channel 7 if you need to.
