Old 8-Jan-2011, 8:34 PM   #11
Originally Posted by No static at all View Post
... Have you tried raising or lowering the antenna a few inches? The antenna may be in a dead spot for RF42 now. You may need to experiment with both height & aim adjustments to see all of the desired stations. Most of my stations are in the same exact direction, but some require aiming off axis due to the large trees in front of the antenna.
Excellent troubleshooting recommendations...
Can you try other locations, 'walk the roof' so to speak?
If you are not seeing any PBS with the 91XG, a DB8 will fair no better.
