Old 12-May-2015, 4:36 PM   #24
Xesvuli420:
It's time for you to try your new DB8E.
The coax should be grounded with a grounding block that is connected to the house electrical system ground with 10 gauge copper wire for electrical safety. For further compliance with the electrical code (NEC), the mast should also be grounded in a similar manner to drain any buildup of static charge, but the system will not survive a direct strike.
Please let us know the results of your tests on this same thread.
Best regards,
rabbit
