Old 11-May-2015, 7:15 PM   #7
Jake V
Here's a re-cap of the stations I'd probably go after (with networks added for translators):
KAWB--28 PBS 34.7 dBm at 26 degrees magnetic
KCCO---7 CBS 32.8 dBm at 215 degrees
KSAX--42 ABC 30.8 dBm at 218 degrees (also MeTV, Antenna TV, This)
K49KQ-49 FOX 6.9 dBm at 147 degrees (also MyNTV, Movies! Bounce)
K16BQ-16 ABC 6.5 dBM at 61 degrees (also MeTV, Antenna TV, This)
K48IF--48 FOX 5.7 dBM at 61 degrees (also MNTV, Movies!, Bounce)
My question about the Winegard HD7698P is how good it would be at receiving signals off the back, since Matt has signals in opposite directions?
For UHF, what about a DB-8e? With one panel (reflector removed) aimed at about 212 degrees (splitting the difference between ABC at 218 degrees and PBS at 26 degrees) and the other panel (with reflector) aimed at either 149 or 61 degrees (for FOX). [Experts please comment.]
