Old 11-May-2015, 3:14 PM   #45
NapMan
I've not used the DB8e, but from what I understand you drill out the rivets holding the reflector on to remove it. To reattach it you use small sheet metal screws where the rivets used to be.
Maybe I should have gone with a less directional antenna? Of course, I don't know yet whether removing the reflectors will help. I guess there's also a chance it will weaken the reception in the other direction (where the reflectors are pointing).
NapMan is offline   Reply With Quote
