Old 11-May-2015, 2:33 PM   #9
I NEED to pick as many as i can.
That usually means a very large all channel antenna, a substantial tower that gets the antenna above obstacles such as buildings or trees, a very heavy duty rotor, and a carefully selected amplifier or a filtering network, all of which could cost thousands of dollars.
However, that's usually not practical, so it's necessary to focus.
Given that you've already jumped the gun and ordered a DB8e, I'd suggest the following: Install the antenna so it's aimed generally south west, then splay each panel about 20-30°away from each other and give it a try. Don't be surprised if it doesn't work out exactly as envisioned.
