Old 8-Jan-2011, 6:31 PM   #5
xcowrnx
Originally Posted by Tigerbangs View Post
You are not in an area where an attic installation is likely to yield good results: you are going to have to go up on the roof. I have installed a few antennas in Madison, and know the pitfalls: New Haven is very easy: Hartford is a lot harder because of the hills between the transmitters and you. The Hartford stations have always been tough on the CT shoreline, but they are available when you use the right antenna system.
Here's how I would proceed: Use a 2-antenna installation: a deep-fringe UHF antenna aimed at Hartford and a small VHF high-band yagi aimed at WTNH. I would use an AntennaCraft Y-5-7-13 aimed at 310 degrees for WTNH, which is a VHF channel operating on channel 10, and use an AntennasDirect XG-91 aimed at 350 degrees. Combine the two antennas's signal using a a Channel Master Titan 7778 or an AntennaCraft 10G221 high-input, dual input preamplifier, and run the cable from the preamplifier to the preamp power supply at the back of your TV set. You will see all of the major CT stations with that combination, and you won't need a rotator to see what you are looking for.
Don't worry about WEDY: WEDH has the exact same programming, and will come off the antenna aimed at Hartford.
Here is a good antenna installation guide to help you:
http://manuals.solidsignal.com/AntInstallGuide.pdf
Awesome! Thanks a ton for the thorough information - I guess I'll get to work on making it happen.
xcowrnx is offline   Reply With Quote
