Old 8-Jan-2011, 6:26 PM   #2
It looks like you are either in a ravine or have rising terrain south of your location. You are in a fairly deep 'shadow' of the terrain between you and Seattle. To be successful receiving the stations you named, you will need to be a bit aggressive. An attic mount has very little chance of success.
I would recommend an Antennas Direct 91XG and an Antennacraft Y10713. Mount the 91XG as high as posssible, aimed at 180° (compass). Mount the Y10713 4 to 6 feet below the 91XG, aiming at 207° (compass).
http://www.solidsignal.com/pview.asp...u=853748001910
http://www.solidsignal.com/pview.asp...0Antennas&sku=
Combine the two antennas with a high input preamp http://www.antennacraft.net/Antennas...mplifiers.html 10G221
The receivers you mention should be digital OTA capable. Windows 7 Home premium includes Home theater PC software with DVR capability. External tuners work well with W-7 http://forum.tvfool.com/showthread.php?t=820
