Old 9-May-2015, 8:36 PM   #6
bebo189
Here is the overhead with the green lines denoting the aiming directions.
Now you can see the aiming directions relative to your homes orientation.
Because your home is new construction, do check for radiant barrier in the attic or Tech Shield shingles as some new building codes to have requirements for energy efficiency.
Well, it looks like there is no radiant barrier/shingles.
Any thoughts on a cheap antenna like this?
http://www.amazon.com/GE-24792-Anten...=attic+antenna
I'm assuming this is omnidirectional. Not sure if I need any kind of amplification/amplifier.
bebo189 is offline   Reply With Quote
