Old 8-Jan-2011, 5:54 PM   #8
No static at all
No static at all's Avatar
Originally Posted by kornnutz View Post
also, on the 91xg, there is a flat bar riveted to the mast right before the active pickup element, mine may have been bent during shipping, should it be horizontal or bent?
That shape of that element doesn't seem to make a difference from my experimentation. I always straighten it out though.
Have you tried raising or lowering the antenna a few inches? The antenna may be in a dead spot for RF42 now. You may need to experiment with both height & aim adjustments to see all of the desired stations. Most of my stations are in the same exact direction, but some require aiming off axis due to the large trees in front of the antenna.
also, I know its a long shot, but would 4 91XGs and a phemt pre-amp pull in the ION station thats in my chart?
The ION station is likely too weak to receive reliably at any reasonable height.
