Old 8-May-2015, 7:59 PM   #5
bebo189
Here is the overhead with the green lines denoting the aiming directions.
Now you can see the aiming directions relative to your homes orientation.
Because your home is new construction, do check for radiant barrier in the attic or Tech Shield shingles as some new building codes to have requirements for energy efficiency.
Thanks ADTech! I will definitely check out for radiant barrier and Tech Shield shingles. Would an antenna recommendation/suggestion depend on if these two things are present in the attic, or can a specific antenna/general antenna type be suggested?
bebo189 is offline   Reply With Quote
