Old 8-May-2015, 7:36 PM   #3
bebo189
You may be in luck, assuming your pic is oriented with north at the top, your roof line is almost lined up with the directions you will get signals from.
Yes, the picture is oriented with North at the top.
Whatever antenna you get will need to go at one end of the house to aim out the gable end. And you have some strong signals close by, most of the stations in green, (LOS {line of sight}), should be easy to get.
(Note the "should be" attics are iffy.)
That is good to know. The area I had planned to install is at the end near one of the gables.
Having said that construction details are important. Some roofing and siding material will block signals. Foil backed insulation is also a signal killer.
I don't believe there is any foil backed insulation in the attic, but I will definitely check out construction materials.
bebo189 is offline   Reply With Quote
