Old 8-May-2015, 2:25 PM   #41
NapMan
No, not always. What counts is the signal path. If lowering the antenna allows a better line of sight than the higher location, then the lower location may well work better, especially when the transmitters are close enough that the earth's curvature isn't yet much of a factor. If the higher location puts the antenna behind a more dense tree obstruction, for example, then the higher location probably won't help. There's also the possibility of a favorable ground bounce providing additional signal for a low-mounted antenna, but that phenomenon isn't likely to occur in a residential area.
I see. I had no idea it was so complicated. I'm not giving up yet. That's why I have a Hulu subscription and use services like PlayOn. If I can't watch my shows the same night I can catch them the next day.
What do you think about rickbb's suggestion about removing the reflector? Since I have stations coming in from nearly opposite directions, might that make the antenna less directional?
NapMan is offline   Reply With Quote
