Old 7-May-2015, 8:30 PM   #1
rotunda169
Having Trouble In Atlanta.
About 4 months ago I had enough of evil Comcastia and decided to cut the cord. I installed an outdoor multi-directional antenna and everything was working pretty well until about 4 weeks ago. I lost the ability to receive several stations and the remaining ones are pixelating from time to time.
I added an older outdoor antenna to the mix with a splitter and everything was great for about 2 days then is started happening again.
Here is my radar report:
http://www.tvfool.com/?option=com_wr...f1f05baf7c8b9f
Here is my setup:
Antenna Direct DB8E multi-directional connected to about 125ft of new RG6 quad-shielded coax. I have a Wineguard LNA700 Boost XT preamp 1 ft. from the antenna and the power injector is 1.5 feet from the TV.
Originally I had the antenna outside on a pole roughly 20 ft in the air facing directly Southwest. I ended up having to drop the height to 6 ft to receive some of the channels. The higher I raise the antenna, the less and less channels I receive (which is odd to begin with). I ended up adding an old WIneguard FL6550A to the run to be able to pick up the CBS channels about 3 weeks ago.
Right now I am recieving the ABC channels (2.1 thru 2.8), 17.1, CBS (46.1 thru 46.3), and 69.1. I lost both NBC (11.1 thru 11.3) and FOX (5.1 thru 5.2). I honestly don't care too much about the rest but really want FOX & NBC back.
What do I need to do, buy, add, take out, or change to make this work? Any help anyone can provide or direction would be greatly appreciated.
rotunda169 is offline   Reply With Quote
