Yes, the reflector on it makes if a very directional antenna.
If the stations you want are mostly 180 degrees away from each other you may be able to remove the reflector to get stations from the back and front of the antenna.
ADTech is a rep for the company that makes the DB4e and can add info for that.
Edit; Generally going higher helps with getting over trees, houses, etc. But not always, signals from the tower can be reflected, (bounce), off of roofs, walls the ground etc. So sometimes lower works better. Fine tuning the antenna location and aiming can be hit or miss depending on local conditions.
I fiddled around with mine for weeks before I finally went up on the roof with a small TV and a short coax cable. Still took me an hour to get it where I wanted it. But that was before the trees leafed out, now I have to move it again.
