I wouldn't hold out any hope on the Sat installers. Some of them are knowledgeable and professional who may have the skill and background in OTA to understand what your issue is.
Most are not, just low wage sub-contractors who are taught the very basics of installing a dish.
If you can get up on the roof and using your TVFool plot and a simple compass and find a likely good place to get around the trees you can tell the installer to put it there.
But before you start drilling holes and putting in bolts, try the reception while someone holds the antenna turns it a bit, even moving it left and right or up and down a few feet this way or that can improve, (or make worse), the signal quality.
