Old 6-May-2015, 2:36 PM   #32
NapMan
I'll say it again: If there are trees in front of the antenna, I have NO expectation of reliable reception of UHF signals. I've worked with thousands of customers (and my own setup) and that lesson has been indelibly ingrained into my advice.
I'm sure you're right. It's likely that as the leaves had filled out in the trees that may be why things are getting worse.
At this point my first step, I think, is going to be raising the antenna. Possibly moving it to the west side of the house but that will require running new coax.
So maybe I will try raising it to about 10 feet above the roof and see how that works. Of course, I don't know when I'll be able to do that but I'll report back.
NapMan is offline   Reply With Quote
