While Tower Guy may be right about using 2 antenna, since you already own the HBU-55, we should probably work with that. Since it is a very large, directional antenna, I suggest that you consider adding a rotator to the antenna, which will allow you to turn the antenna towards the various transmitters. Additional antenna height might also help, as well, but the rotator will allow you to use your existing antenna much more successfully.
I know Tower Guy's disdain for rotators, and I understand why he feels that way, but in a situation such as yours, I believe that using a rotator is warranted. Decent rotators include the Channel Master 9521a and the AntennaCraft TDP-2.
