I think you should attach just the coax to a TV and leave the distribution amp out of the picture until you fine tune your aiming and then report back on what you are getting. It can be a little tedious sometimes to find the sweet spot.
I would also double check the antenna and make sure all the elements are properly snapped into place (see this
review) and also check the phasing lines to make sure they are not shorted out somewhere.
