Old 30-Apr-2015, 1:50 AM   #4
I gave no idea what your existing mounting location looks like or where it's situated, my concern is that you ensure that you have an optimized line of sight towards your weakest UHF stations, in particular.
Assuming that you can achieve that, my suggestion is for a reflector-less DB8e with both panels aimed at WCTX. This will focus on the UHF stations only and, if you also require any of the VHF stations, you may well find that a separate antenna is needed for them.
Do not use any amplifiers unless advised to do so.
