Thread: Carrier signals
Old 29-Apr-2015, 3:19 PM   #11
Jake V
You do best to contact UNC-TV directly and ask them if they've ever started broadcasting UNC-MX on their OTA network. It's quite possible that they've set up their OTA encoding equipment to add the slot for the fourth programming stream with null data(which would make the additional channel show up in your channel list) but they have not yet made the final improvements necessary to actually carry UNC-MX OTA.
That makes perfect sense. Here in Washington, DC WFTC-DT had 14.3 and 14.4 showing up with no content. It turned out they were doing periodic tests to put content on those sub-channels. Eventually they added full time content.
