Old 29-Apr-2015, 2:19 PM   #2
You'd need to add the VHF-1 Retrofit Kit to the C1C. The C2V already includes it and its available in most Walmart and Best Buy stores nationwide. Purchase RG6 coaxial cable separately on an as-needed basis.
WPVI operates on VHF channel 6 which is outside the design band of the VHF element, but they run a ton of power to help penetrate buildings for indoor antenna users. Consequently, we've found that the standard VHF element performs adequately in most cases within 20 miles of the Roxborough (depending on other variables).
The "conventional" recommendation would be for a small all-channel antenna. You *might* find that necessary as your backup idea.
