I am looking into a similar issue. I talked to Winegard's support team. They recommended two of the same antenna models spaced no closer than 2-1/2 to 3'' from each other. Make sure the coax from each antenna is approximately the same length to the combiner like their Winegard C-7870, which is built for two antennas. Power one antenna and make the 2nd one passive. No guarantees the set up will work but, they have a 90 day return policy and if you call tech support they will give you good advice. If this doesn't work there is always a rotor.
