Old 27-Apr-2015, 5:17 PM   #13
Tim
You are getting all the majors in Atlanta plus many of the low power stations that are often difficult to receive in the suburbs OTP (that's Outside The Perimeter highway for all you non-Atlantans). You will find that the sub-channels will have a lesser quality picture than the main channel because they are broadcast at the lower resolution of 480i and a lower data bit rate. This is really apparent on channel 32 WANN which packs 10 video streams and 10 audio streams onto their one 6 MHz channel width. WPCH is on the same tower as WGCL and at the same power, but their antenna is about 60 ft lower. Some slight tweaking of your antenna location should be all that's needed. Enjoy!
