Old 25-Apr-2015, 4:39 PM   #4
StephanieS
Ok.
I'd suggest if small is the goal, mounting the Antennacraft HBU11k on the balcony. It is a compact VHF/UHF antenna. Not much larger than a 24" widescreen monitor. It comes with a J Pole antenna to mount.
It looks like this (similar model RCA ANT751):
I would encourage you at a minimum to use this antenna. It has proper VHF support. Any flat panel antenna you purchase to put in your window doesn't have that.
You could probably point it to magnetic 166 to point at the US stations and all the local Montreal stations should be just fine off the sides.
Cheers.
