Old 25-Apr-2015, 3:06 PM   #3
eakl8
Hi Stephanie,
thanks a lot for your suggestions!
Few more details: in the attached image you can see both the window that gives in the room with the TV, and the balcony I was talking about.
The line of sight straight out the window and balcony I would say is quite unobstructed, near houses are low and there are just a few branches of trees close. From what I can understand, I suppose I could have straight access to that bunch of channels I see on the report around mag.118° (7,11, 24..) since there's a park in that direction too.
As you can see the balcony is not that big, aren't those antennas you suggested too big for it? I would rather try to stick with some smaller solution, because of the size and also because I am on rent at the apartment.
I don't mind much about the US channels, would be great if I could have them, but not a priority if I can have a more compact solution instead.
Is there anything that could do a decent job in this situation??
File Type: jpg Schermata 2015-04-25 alle 10.22.24.jpg (412.7 KB, 1519 views)
eakl8 is offline   Reply With Quote
