Thread: Hilly In Utah
Old 25-Apr-2015, 1:12 PM   #7
StephanieS
Using your 91XG to test the new location is the way to go. Sometimes TVfool reports are stingy, other times are optimistic. You just have to try. At your new location, things look pretty difficult. That said, you might be in a sweet spot.
Working in 2-edge situations, be prepared to play around with various locations for testing. From ground level to roof height. I have a 2-edge condition real channel 12, its sweet spot for me is 4' above ground.
Cheers.
Originally Posted by davidlukewilcox View Post
I'm going to have about 4-6dB less after the move than I had before. Do you think that this is even doable since the signal is so weak?
