I usually just go straight to the C2V, it's my favorite for use indoor. If you pick the newest version up from Walmart or Best Buy, it should be capable of free standing placement. You could also try the C1 convertible, a close second choice, but you'd have to order the VHF kit separately off our web site.
FYI, the newest versions of both the Micron reflector and the newest version of the VHF-1 module are now made so they will mate together. This has been a rolling change, so there's really no good way to determine what you have until you examine the units.
Because you're a thousand plus feet below the transmitting antennas, your signals will be markedly lower than the levels indicated in your plot. Overload won't be an issue unless an amplifier gets into the system.
