Old 22-Apr-2015, 6:36 PM   #4
Could you recommend a particular outdoor antenna for that purpose?
That's a tough question for a difficult location, but I'll give it a try.
Most of the indoor antennas are the flat type, which you have already tried.
The reviews of indoor antennas are mixed and varied going from Great to Awful because indoor reception is much more difficult than with an outdoor antenna. When the FCC made their original tests of digital reception, they assumed that everyone would have at least an outdoor antenna at 30 ft. and set the transmitter power levels allowed based on that assumption.
They soon found out that those power levels were not adequate, and have needed to authorize higher power levels for the same coverage areas as analog signals.
However, in your case, the signals outside at your location are so strong that the signal power for your strongest signal is highlighted in red (-11.2 dBm) to indicate possible overload.
So, the problem in your case is two-fold. The strength of your signals inside your apartment is unknown, because the attenuation of the building construction is unknown.
The second problem is multiple reflections of signals that interfere with the direct signals from the transmitters. This is called multipath. The reflected signals arrive at your antenna at a different time than the original signal, which interferes with the original signal and causes errors in the digital stream. The tuner is able to correct errors up to a certain point using the FEC (Forward Error Correction). When that limit is exceeded, the signal suddenly develops pixilation and freezing at the "Digital Cliff" and finally drops out.
In the days of analog television we also had multipath reflections which created a secondary image that we called "ghosts."
Since you have already tried a flat antenna, the only improvements I can think of are to try different antenna locations, try adding an attenuator after the antenna because your indoor signals might be so strong that they create tuner overload, and add a reflector to an indoor antenna to make the antenna more directional to eliminate some of the multipath reflections.
Variable Attenuator
The antennas with reflectors that you might consider are made by Antennas Direct. They are more expensive than many indoor antennas, so you will need to decide how much you want to spend on antenna experiments. I can't guarantee that my ideas will work, and would like forum member ADTech to double-check my analysis, because his advice is excellent.
The antennas that I would consider have reflectors, and are primarily for UHF, so you would need an added VHF antenna for real channels 7 and 9.
Indoor Antennas
https://www.antennasdirect.com/store...-antennas.html
All Antennas
My choices:
ClearStream Micron R Indoor Antenna, Black or Colors
Does have a reflector, but isn't for VHF. You would need to add a separate antenna for VHF with a UVSJ UHF/VHF combiner.
ClearStream™ 1 Convertible Medium Range Indoor/Outdoor DTV Antenna
https://www.antennasdirect.com/store...V-antenna.html
You would need to add the VHF Retrofit Kit for VHF Antenna Reception
https://www.antennasdirect.com/store...rofit-Kit.html
Possible upgrade: ClearStream™ 2V Long Range UHF/VHF Antenna Complete Combo Pack
https://www.antennasdirect.com/store...-Complete.html
DB2e Extended Range Outdoor TV Antenna
https://www.antennasdirect.com/store...r-Antenna.html
If 7 and 9 aren't good enough with the VHF Retrofit Kit, you could add a separate VHF antenna with a reflector like the ClearStream™ 5 VHF Ultra Long Range Outdoor TV Antenna
Some cases of multipath reflections are so severe that it has been necessary to enclose the antenna in a metal enclosure, with an open end in front of the antenna, to limit the antenna beamwidth to a very narrow angle.
Chattanooga TN: Got Atlanta But Few Locals
The thread:
http://www.avsforum.com/forum/25-hdt...-locals-2.html
Photos at post 60:
http://www.avsforum.com/forum/25-hdt...l#post21358820
Bill Naivar of Georgia Tech also built an anti-ghosting antenna in a trash can. I see that the link is still listed on Google, but Norton Internet Security has warned me off and blocked me.
