Old 22-Apr-2015, 1:11 PM   #9
Again, image quality will be perfect as long as you stay on top of the digital cliff.
If you are focused exclusively on the NYC stations, there is no performance downside of using the larger all-channel antenna. Just keep in mind that the C490 is 12.5' long and 9' wide at the back and it weights in at almost 11 lbs. Be prepared for its size, handling difficulty, and mounting requirements. You may also have to buy your matching transformer separately, check on that before leaving the store.
