Old 22-Apr-2015, 1:08 AM   #1
RiggedToFly01
I got some Channels, Got some questions.
First off, Here is the link.
http://www.tvfool.com/?option=com_wr...f1f09abed0787c
My antenna is the RCA ANT751 Durable Compact Antenna
The above 2 pictures are my setup. I know it's upside down but it allows me to have a full 360 range in my attic. From the antenna there is about 40ft of RG6 to get to the basement where it meets a splitter from there 1 50' run of RG6 to my living room. 1 run of what I guess is RG59 to the Master Bedroom it is in the walls already. I can't imagine it's longer than 50'.
The above picture is taken from below. Which end should I be pointing? The "A" or "B" end?
I have 2 tried random positions so far and I get the channels I need. But I would like to get the most I can. The first position I attempted was the "A" end pointing SW. 16 Channels. The next was turning it 180 degrees. After that 27 Channels. Is there a better way of doing this? Thank you.
RiggedToFly01 is offline   Reply With Quote
