Tv Antennas and Reception
Having the antenna directly connected to one Tv or converter box with no splitters is helpful and if that one Tv or converter box has the ability to select digital channel 4 with out scanning , that will make it easyer. . Another way to eliminate or reduce undesirable multipath is horizontal stacking of 2 identical antennas side by side. One antenna is in a fixed position and the other antenna is moved closer and further away , to find the distance between the 2 antennas that creates a 'null' of the undesirable multipath reflection.
