Old 21-Apr-2015, 4:25 PM   #10
skatingrocker17
Originally Posted by drew1942 View Post
Thank you, that is heartening news Skatingrocket17. Your VHF, UHF combo is one powerful one and if anything would work I guess that would be it. What did you use to combine/amplify the signals? Were they on one mast or on separate masts. If on one mast how far apart were they and I would assume that the UHF antenna was above the VHF antenna? When I set my combo up sometime early next month I hope to report on how it went. Not enough of a fanatic however to relocate to North Baltimore to solve my problem
I used the Antenna's Direct EU385CF combiner. When I used the DB8e I actually used it by itself, now I use the separate VHF antenna and Antennas Direct 91XG (because it takes up less space vertically). They are maybe 2-3 feet apart on the same mast. I'm only using a distribution amp to split the signal 4 ways.
I'm actually moving to Canton next month so then I'll be trying to get my Toledo stations still. But it shouldn't be too hard.
skatingrocker17 is offline   Reply With Quote
