Old 21-Apr-2015, 1:21 PM   #2
StephanieS
Greetings,
Trees are signal killers. This is a problem for your situation. Especially given that Sacramento's main signals are south and those trees are in the way.
On your property is there an opening you can shoot through between the trees or are you completely blocked off to the south? It might be good to go and see if there is any way to get an opening to the south.
That Winegard you are using a small fry. I might try a Clearstream 2V in your situation pointed at magnetic 200. Keep in mind though, with those trees, even with a high horsepower antenna, swaying branches and obstructions are things antennas cannot compensate for. An antenna can only work with the signal that is actually getting to the antenna. If a tree is reflecting 25% of that signal away, you see the problem.
Cheers.
