Old 21-Apr-2015, 3:10 AM   #1
yzman720
Here is my setup with video - done correctly?
My location: http://www.tvfool.com/?option=com_wr...f1f02acbbb24b5
Video of setup: https://youtu.be/uB75xurooEY
sorry about the quality first video I have never done!
I went with the db8e and the clearstream 5
I have the db8e & catstream 5 going into a vhf/uhf diplexer and then running into a juice preamp, from the juice my powered wired will run 25-30' to the telecommunication box and split off to the TV's in the home from there.
I have 3 questions -
1. My attic does have some metal strips here and there from the trusses and some can lights does it look like it will interfere?
2. My compression fittings on my rg6 cables do not have rubber o rings in them and the 2 cables that came with the db8e do have rubber o rings - Do I need to redo all of mine and buy some o rings? I did use dielectric grease on each fitting.
3.My interpretation of my map is I need to face the db8e at 65degrees and the catstream 5 at 55 degrees. Is this an accurate interpretation?
yzman720 is offline   Reply With Quote
