Old 18-Apr-2015, 5:58 PM   #4
signals unlimited
PA. DTV reception
That is a directional antenna and should do fine. Any larger antenna would need a stronger mount. You can mount the 7694 on the satellite mount and add a pre-amp if you need more power, however the distribution amplifier should be all you need to supply enough signal to all sets for stable reception.
