PA. DTV reception
If your dish is on the roof with a clear view to the SW, you could use the sat. mount and coax to install a Winegard HD7694 antenna aimed to the SW channels in your report. If there is more than one coax, be sure to identify it from the antenna to your point of distribution. Keep the ground block in the path, remove all other satellite splitters, and install a Channel Master 3414 distribution amplifier to feed your sets.
