Old 18-Apr-2015, 4:46 AM   #1
Heliophobe
Cape Cod, MA UHF antenna advice
I am finally set to cut the cable. Just looking for antenna advice. Been lurking here on and off for a year or so.
Did the interactive map and have a report here:
http://www.tvfool.com/?option=com_wr...f1f0cb65a9eac5
I am looking to get UHF Boston ota signals which are roughly 61 miles away at 326°. Only really care about CBS, ABC, NBC and Fox. Anything else is a bonus, including the Providence, RI signals at 298°.
I currently pick those up with a cheap GE attic antenna my brother gave me. All crystal clear save WNAC channel 12 which has slight signal issues. And it is pointed at Boston since the crawl space I put it in doesnt allow it to point to Providence.
This is the cheap antenna btw:
http://www.walmart.com/msharbor/ip/G...tenna/20976617
I will be putting a roof mount antenna at 25' and I dont want 2 antenna up there. I will have two TVs hooked up. I was originally thinking of getting a winegard HD8800. Then thinking of an antennas direct DB8e but hoping a DB8 might be good enough. Also looking at a CM 4228HD. Assuming a preamp will be required as well.
Anyone have experience with uhf antenna for 60 + mile away signals?
Thanks in advance.
Heliophobe is offline   Reply With Quote
