Old 18-Apr-2015, 2:08 AM   #2
Welcome to the forum, Tonye:
These are tvfool reports at different heights using your coordinates:
no height specified:
http://www.tvfool.com/?option=com_wr...f1f00a6311e7b6
25 ft:
http://www.tvfool.com/?option=com_wr...f1f08263c6b640
50 ft:
http://www.tvfool.com/?option=com_wr...f1f05434a3d41c
75 ft:
http://www.tvfool.com/?option=com_wr...f1f04314f4113f
100 ft:
http://www.tvfool.com/?option=com_wr...f1f06755bbc3af
If my results match your tvfool report, you may want to delete your coordinates from your post to protect your location.
I first entered your coordinates here using the interactive map feature of tvfool and saw in the aerial view that you had enough room for a tower in hopes that if your antenna was high enough you might have a chance for ABC:
It looks like you would need at least 75 feet for a fairly good chance at ABC with a high gain antenna, considering it is a Tropo signal. You would also need a preamp, but your strongest signal WMAU-DT on real UHF channel 18 would probably overload the preamp. That would require a custom single channel bandstop filter for channel 18 to weaken WMAU-DT. How badly do you want ABC?
Even if you were willing to do without ABC, you would still need the Tin Lee custom filter to get the other channels.
http://www.tinlee.com/MATV-Bandstops.php?active=3#CR7
Call them first and talk to their engineer and email your tvfool and FM Fool reports, and a link to this thread to him.
I would suggest a Winegard HD7698P antenna and an Antennas Direct Juice preamp. You would also need an FM trap/filter to weaken the very strong WMAU-FM:
Disclaimer:
Your situation is very difficult; no guarantees.
