Old 18-Apr-2015, 12:17 AM   #2
Welcome to the forum, Tim:
Your signals are very strong. What channels do you want? The first 14 on your tvfool report give you a good selection of networks.
Do you want to try an indoor antenna first, or are you allowed to install an antenna on the roof?
Do you have a window, with no low-E glass or a metal screen, that faces SW that will enable you to have an indoor antenna just inside the window? Maybe not, because it looks like the signals are coming in towards the end of the building.
If the TV height is 5 ft, does that mean you are on the ground floor? I see a lot of trees in front of the building that might affect the signals.
I entered your address here, using the interactive map feature, to get an aerial view at 45 degrees:
