Old 7-Jan-2011, 8:53 PM   #20
youngclarkh
You need a very good antenna to reject multipath, even for the translators. Your antenna is capable of low band reception. I'd guess that the difference is a better F/B ratio on UHF than VHF. Those mountains to the east of you are very close and very tall.
In order to get FOX, I'd still try a 91XG, and then you should get NBC too.
First) Are you suggesting a 91XG directed at the translators? If so, how would that get me 25 (FOX) since it doesn't transmit from there?
Second) The 91XG is not supposed to get VHF in a range low enough to pickup channel 4 (NBC).
I'm confused
youngclarkh is offline   Reply With Quote
