Old 16-Apr-2015, 1:43 AM   #5
afton
OK, it's up. Still have a little bit of work to do with finishing up the mounts and grounding and still need to route the wiring permanantly. I temporarily ran the wire under the garage door to the tv in the basement, the one with the weakest tuner.
Turned toward Knoxville, it tunes in 37 channels. Almost all of the Knoxville channels come in, the exception is surprisingly the one with the strongest signal rating on the charts. It is also on the VHF band rather than UHF band. Maybe it will come in on one of the other tv sets.
All of the tri-cities channels as well as the Asheville channel come in good from the back or side so I could have probably skipped the rotor and just mounted it permanently turned toward Knoxville.
afton is offline   Reply With Quote
