Old 15-Apr-2015, 10:57 PM   #3
m9610172
Repaired link: http://www.tvfool.com/?option=com_wr...f1f019dcd2f415
If Tom (GroundUrMast) is around, he's best to answer your query as he's in your area.
Eliminate the "AmazonBasics" (a private label Mohu Sky) and the CM 42228. The 7694 is a good potential choice, but it's hugely a PITA to fold back up if you have to take it out of the attic. The HBU33 is of similar performance to the 7694 but is getting harder to find in the aftermath of Radio Shack's bankruptcy and Antennacraft's apparent demise.
Attics are pretty much unpredictable locations for antennas. You'll never know what's going to work until you get an antenna up there and try it out.
Thanks for your response.
You are basically saying multi-directional antenna is not going to work, right? I saw RadioShack nearby had HBU33 a couple of weeks ago. I’ll try it and return it if doesn’t work.
One question. Is AmazonBasics going to work if I install it on roof?
m9610172 is offline   Reply With Quote
