Old 15-Apr-2015, 8:19 PM   #5
naperjp
Since it is inside and out of the weather, I don't think you would have a problem to just add the required length of cable to the existing cable run using a barrel connector.
My signal is already a little dicey on some channels. I'm not sure if that's from having a splitter with unused ports (I do have terminators on the unused ports), poor antenna positioning, longer runs between amp and splitter, etc. I wasn't sure if adding another connection mid-way between the splitter and the tv would degrade the signal even further, and if so how much.
Funny thing is, typically in Chicago CBS has the worst signal, but for me that's coming in better than NBC is....
naperjp is offline   Reply With Quote
