Your best bet is a large, all channel antenna aimed at Philly. The antenna will be huge. A rotor that is capable of handling it without breaking will be expensive. The satellite dish mount may or may not be suitable and may or may not be in the right location on your roof. Depending on how long a cable is needed from your antenna mounting location to your distribution point, you might be able to use a distribution amp with no preamp or you might need a preamp plus a passive splitter. It depends on the relative cable lengths and whatever signal you can get off the antenna.
