Old 15-Apr-2015, 5:21 PM   #1
cdvanhorn
Antenna Selection Help Northern KY
Hello,
I'm looking at ditching satellite TV, and I would like advice as to what it would take to get TV reception at my location. The challenge for my location is not the distance it's that I live in a valley.
  • Signal Analysis: http://www.tvfool.com/?option=com_wr...f1f04be113b237
  • I don't have any existing equipment except for coax cable. The antenna output will only need to be split once to two different PC capture card/tuners. The cable run into the house would be around 50 feet.
  • I would like to receive CBS, NBC, ABC, FOX, and PBS. I don't care about the other stations.
I was looking at getting the Antennas Direct DB8e for UHF reception and a Antennacraft Y5-7-13 for my lone VHF channel. The antenna(s) would be mounted outside on the roof at about 20-25 feet above ground level.
What setup would you recommend? Would you recommend any preamplifiers? If you need any more information please let me know.
Thank you for your time.
cdvanhorn is offline   Reply With Quote
