Old 14-Apr-2015, 6:05 PM   #6
yzman720
ok I appreciate the input that helps a lot!
This is what I believe I am going to go with -
An attic mount db8e and a clear stream 5 hooked into a vhf/uhf diplexer that hooks into a juice preamp next to the antennas. I will then run the coax from the juice in the attic to the telecommunications box 25-30' away into a powered 4-Output TV / CATV Distribution Amplifier. This is where I will power the pre amp and the distribution amplifier in the telecommunications box. Does this setup seem acceptable?
Antennas direct informed me no grounding is necessary at all due to this being attic mounted and all in door runs. is this accurate?
yzman720 is offline   Reply With Quote
